EAGLE User Support (English) Searching Libraries
  • Subscribers 189 subscribers
  • Views 1954 views
Searching Libraries
Is there an easy (or any) to search through the libraries to find a
component? I don't necessarily have the manufacturer info for a lot of my
electronic components so it can be difficult to find the appropriate part.
Also, even if the manufacturer is known there can be nested groups so
unless you expand them all you may miss it.
For example, I'm trying to find parts for (1) Microchip PIC16F1825, (2) CUI
Inc rotary encoder (ACZ11) and (3) straight double row male headers (e.g.
p64 of Jameco's catalog) but not having any luck looking through the parts
list by eye.
    Thanks Jim and db. I can't believe I missed the search box (or that
    wildcards would work).
    No sign of the PIC16F1825 however it has the same # of pins as the 16F688
    so I guess I'll look into copying that device into a custom library. If
    anyone has a link to a good reference to do that, it would be much
    appreciated.
  • fritzz
    fritzz over 14 years ago
    Microchip just seems to have them by package type. Search for: microc*
    For female headers search fe*-*
    or just expand "pinhead" folder for males
    list by eye.
    One easy way is....
    a) Go to eagle control panel:  Make sure that all the libraries are used
    (Green ball next to the library name).
    b) From the schematic editor click on "Add"
    c) In the dialog that pops up near the lower left hand corner it will
    say "Search".   Select all three checkboxes and then type into the text
    entry the search term.   Use * for wildcards (eg "SOIC") to find all
    the approximately matching items.
    d) Use the least restrictive search term possible and then if you get
    too many hits you can tighten the search.
    Jim
