EAGLE User Support (English) How to add text to Groundplane?
  • Replies 8 replies
  • Subscribers 189 subscribers
  • Views 1892 views
My board includes a couple of items of text >DRAWING_NAME and
>last_date_time.
What I'd like to do is to have these two items appear in copper on the
finished board. This can be done very simply, just by putting the text in
the appropriate place on the board and making sure it get printed with the
artwork. The problems comes when I also want to add a groundplane, I can do
this quite easily, and the groundplane will 'flow' around all the tracks
and pins, however it will overwrite the text.
I could move the text to somewhere where there is no groundplane, except
that the only place on the board where I do have space for the text is
right in the center!
Any solutions?
Cheers
    Add Text in the tRestrict or bRestrict Layers, I think this helps.
    https://www.youtube.com/watch?v=RqXX1NPS_hIhttp://
  • jlopez2022
    jlopez2022 over 10 years ago in reply to e14 Contributor
    If the rectangle is in the bottom layer (as example the bNames layer), do not forget to activate it at the manufacturer site (usually there is not extra cost)
    Thanks guys, a colleague suggested a better solution. Apparently a filled
    polygon should  NOT overfill text, I re-installed Eagle and it started
    behaving as it should. (I also tested the first solution above and can
    confirm it works.)
    Cheers
    James Morrison wrote:
    warrenbrayshaw wrote on Fri, 29 June 2012 16:34
    >> You can mark out the the area of the polygon you want clear with a
    >> rectangle
    >> or polygon drawn on tRestrict (for the top layer poplygon ) and place
    >> your
    >> text within it.
    Right, that works on top and bottom layer.  That doesn't work on inner
    layers.  If you do this you want to draw lines on the t,bRestrict
    layers and place the text inside of that.  If you use a rectangle
    then you'll get DRC errors of the copper text in the area where there
    shouldn't be any copper (that's what a restrict area is)................
    James.
    True, and much better. You also need the polygon orphans turned off which
    may not suit in all cases.
    Warren
    news.cadsoft.de
    rectangle
    your
    text within it.
    layers.  If you do this you want to draw lines on the t,bRestrict layers
    and place the text inside of that.  If you use a rectangle then you'll get
    DRC errors of the copper text in the area where there shouldn't be any
    But I forgot that V6 has a much better solution:  cutout polygons.  Here,
    you just draw a polygon where you want the voided area and flag it as a
    cutout (change polygon pour type from solid to cutout).  This is a much
    nicer solution and is useful for all kinds of reasons.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    You can mark out the the area of the polygon you want clear with a rectangle
    or polygon drawn on tRestrict (for the top layer poplygon ) and place your
    text within it.
    Warren
    news.cadsoft.de
    lima7 wrote on Fri, 29 June 2012 05:51
    >last_date_time.
    the artwork. The problems comes when I also want to add a groundplane, I
    can do this quite easily, and the groundplane will 'flow' around all the
    tracks and pins, however it will overwrite the text.
    except that the only place on the board where I do have space for the
    text is right in the center!
    Any solutions?
    Yes, if you want a void in the middle of a polygon then you have to draw
    two "C" shaped, overlapping polygons that have the same rank and named with
    the same net name.  Then the copper will flow into each other except in the
    center.  Then the copper text you put there won't be flooded over and you
    won't get any DRC errors either.
    Cheers,
    James.
    Do you mean the ratsnest that you apply connectied to ground by term 'Ground plane'  ?
