EAGLE User Support (English) bulk disapprove of ERC errors?
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 1683 views
Eagle 5.11
Working on a new version of an old board. Got about 200 "errors" that were
reviewed and approved. Now I want to go back and review everything from
scratch. What is the best way to do this?
If I pull up the DRC errors, I can see the approved ones and disapprove them
individually. Is there a way to do this in bulk?
tia - Oppie
    On 05.07.2012 21:27, Oppie wrote:
    Eagle 5.11
    were reviewed and approved. Now I want to go back and review everything
    from scratch. What is the best way to do this?
    them individually. Is there a way to do this in bulk?
    tia - Oppie
    just use the repeat function of the hotkey.
    Select the first "Approved Error" in the Errors list and keep
    Alt + A pressed until all errors are gone. It takes some time
    but saves mouse clicks.
    Richard Hammerl -- EAGLE Support
    autodeskguest over 9 years ago in reply to xadidas
    On 25/08/2017 5:04 a.m., Eric Jalbert wrote:
    I found a way to do that.  Just rename your .BRD file to .XML then use a standard XML editor, and delete all <approve /> tags between the <errors> and </errors> tag and your approved errors are no longer approved!
    Hope this helps!
    Eric
    As there is not much with Eagle to entertain me these days, I created
    the attached ULP.
    With it and from the board editor you can unapprove,in bulk, all the DRC
    errors you have previously approved. It makes those same changes to the
    board XML while the board is displayed.
    If the attached file does not make it to Element14, get it from
    EagleCentral.
    Enjoy
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    Hope this helps!
    Eric
    the attached ULP.
    EagleCentral.
    Enjoy
    Warren
    Thunderbird!
    support forums.
    Hope this helps!
    The original question related to V5. Your method only works for V6 onward.
    Am 05.07.2012 um 21:27 schrieb Oppie:
    Eagle 5.11
    tia - Oppie
    Hi Oppie,
    in case you still work with version 5 then get the latest 5.12.0
    It has some features and can handle the U-parameter.
    (read /doc / Update_eng.txt / Miscellaneous)
    This allows you to change the position and the name of the eaglerc.usr
    file,so you can run different versions of eagle.
    Joern Paschedag
  • xadidas
    xadidas over 9 years ago in reply to e14 Contributor
    Hope this helps!
    Eric
    Warren Brayshaw schrieb:
    >> You need to run DRC after the first move - I think that will remove
    >> all approvals of the old positions.
    >> After that, you can move back and then run DRC again.
    Doesn't seem to. I thought that it would work that way as well. The approved
    list is somewhat protected and unless you specifically unapprove items they
    remain in the design file.
    So every time you want to freshly re-check the design, you need to move
    it to a position where it has never been before...
    Sorry to say this, but that's crap.
    Tilmann
    >> I investigated Tilmann's suggestion and found it only works if you
    >> don't return the design to the original position. Even saving the
    >> moved design and reopening the board, the approved errors are still
    >> within the design file so if you then position the board back to its
    >> original position, the approved list reappears.Still qualifies as a
    >> work around though image
    Tilmann
    DRC
    'Approve the error'
    Group all
    Move(>0 0)(1 1)
    DRC....'Note the return of your original error'
    Move(>1 1)(0 0 )
    DRC
    the approved error has reappeared
    HTH
    Warren
    news.cadsoft.de
    I investigated Tilmann's suggestion and found it only works if you don't
    return the design to the original position. Even saving the moved design and
    reopening the board, the approved errors are still within the design file so
    if you then position the board back to its original position, the approved
    list reappears.Still qualifies as a work around though image
    You need to run DRC after the first move - I think that will remove all
    Tilmann
    Tilmann Reh wrote:
    Oppie schrieb:
    >> Eagle 5.11
    >> that were reviewed and approved. Now I want to go back and review
    >> everything from scratch. What is the best way to do this?
    >> disapprove them individually. Is there a way to do this in bulk?
    Interesting question ... I don't know of a direct way.
    Workaround: GROUP all, and then move the complete design by some
    amount. (Maybe you move it back later.) Since the approval marks are
    related to the object coordinates, the next DRC will detect all
    errors again.
    Tilmann
    Warren
    news.cadsoft.de
