EAGLE User Support (English) Finding tool location
  • Views 407 views
I am trying to track down an odd-ball drill size on my pcb.  It is
referenced as:
T03
X33810Y21006
I can not find in the eagle.def file which format the coordinates are in
(eg 2.4).  Assuming that Eagle is 2.4 LZ from looking at old posts, that
would tell me the drill hole should be at 3.3810, 2.1006.  When I go
there though there is no hole.  What am I missing?  BTW, I have no
offset defined in the CAM processor job.  I have included the EXCELLON
info from eagle.def below:
Type     = DrillStation
Long     = "Excellon drill station"
Init     = "%%\nM48\nM72\n"
Reset    = "M30\n"
ResX     = 10000
ResY     = 10000
;Rack     = ""
DrillSize  = "%sC%0.4f\n"        ; (Tool code, tool size)
AutoDrill  = "T%02d"             ; (Tool number)
FirstDrill = 1
BeginData  = "%%\n"
Units    = Inch
Select   = "%s\n"                ; (Drill code)
Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
Info     = "Drill File Info:\n"\
           "\n"\
           " Data Mode         : Absolute\n"\
           " Units             : 1/10000 Inch\n"\
           "\n"
    On 7/6/12 6:19 PM, John Friede wrote:
    On 7/6/2012 3:49 PM, Andrew Sterian wrote:
    >>> referenced as:
    >>> T03
    >>> X33810Y21006
    >> I'd load the file up in a Gerber viewer (GC-Prevue, gerbv, etc.) and
    >> navigate to 3.38",2.1". You'll be able to see the relevant hole.
    >> Even if you don't have offsets defined Eagle will add some in to make
    >> sure everything is away from the origin and there are no negative numbers.
    >> Andrew.
    Thanks!  I didn't realize Eagle added it's own offset in.  Looked at it
    in Pentalogix and found it. How does Pentalogix know what the offset is?
    It doesn't. But everything else on the board is offset too, so even
    though the X,Y co-ordinates are unfamiliar to you relative to what they
    are in Eagle, they are familiar when viewed relative to everything else
    on the PCB, which has also been offset.
    In other words, there is an offset between the Eagle PCB co-ordinates
    and the Gerber file co-ordinates. You don't know what it is, but it
    doesn't matter because the offset applies to everything.
    Andrew.
    >> referenced as:
    >> T03
    >> X33810Y21006
    Andrew.
    referenced as:
    T03
    X33810Y21006
    Andrew.
