EAGLE User Support (English) Tapering Transmisson Line in EAGLE CAD
  • Views 1062 views
hello every one,
I am designing an evaluation board for an IC using EAGLE CAD, whose
information can be viewed on this link
http://www.hittite.com/content/documents/data_sheet/hmc144lc4.pdf. the end
of this document shows the pcb for this IC.
I have designed something shown in the attached image(zoomed only to show
ic connections).
Since all the lines are 50 ohm, their width is about 0.45 mm. a close look
shows that the IC pads are smaller then the microstrip line i.e 0.25 mm.
Will this huge width affect the neighboring pad which are connected to
ground plan.
From the data sheet they suggests the line tip attaching the IC PAD shall
be tappered.
So how can i apply tapering in EAGLE CAD, and what is the theory behing it,
how to select tapering width and how much length to tapered..
    Am 11.07.2012 15:40, schrieb Usman Ali:
    ic connections).
    I advise NOT to connect wires of that large width to the IC.
    ground plan.
    Yes. The possibility of short-circuits during manufacturing will be MUCH
    higher, and you might even need to pay extra due to very small copper
    distances.
    be tappered.
    There is NO special function for that, so just draw it manually:
      1. Using the SMD width of your IC, route from the IC to where the wire
         should get thicker.
      2. Change the width of future wires to the large width that you need.
      3. Route from the last point to wherever you want to.
      4. Now you have a thin wire getting thicker at the desired point.
      5. If you want the wire thickness to NOT change abruptly, choose the
         thin width again and insert additional sloping wires. Pay attention
         that the new wire starts EXACTLY on one existing wire, otherwise
         the DRC will complain later.
    Andreas Weidner
    I don't know of any "simple" tapering method.
    Run short 0.25mm stub traces away from the IC pads and then connect
    your normal width 0.45 trace to it. This will also minimize any solder
    bridges between pads.  You may be able to just change the width of the
    final trace segment to the pad, since you already have connected the
    wider trace.
    ~Marvin
    On 7/11/2012 6:40 AM, Usman Ali wrote:
    hello every one,
    ic connections).
    ground plan.
    be tappered.
