EAGLE User Support (English) problems gettint the schematic editor to run
  • Views 238 views
I purchased Eacle 5.2 about 4 years ago to make a schematic board. And
haven't used it since. This had the schematic editor and the board editor.
Now I get a message that I don't have the schematic editor module when I try
to open it.
Wendell
    to open it.
    If you open "help / about EAGLE" you can see your license data.
    The license number is followed by up to three letters for the different
    modules (L for Layout, S for Schematic, and R for AutoRouter). So you
    might first check your license data for correctness (personal data,
    licensed modules). If only the licensed modules differ from what you
    paid for, you should contact CadSoft for a new license file.
    (Maybe you try to install your original license before you contact them.
    See "help / EAGLE license" in the control panel.)
    Tilmann
