EAGLE User Support (English) Line lengths change
  • Subscribers 189 subscribers
  • Views 476 views
Line lengths change
skyflyrr
skyflyrr over 14 years ago
Is there a way to create a line and specify/change its length once it is on your board layout? I brought up properties on some lines I drew and thought I could specify the length I wanted, but it is not allowed on the properties box? A way to specify after the fact eliminates having to look at coordinates or trying to start at a certain location to determine length. This should be available via a properties menu.
Bob Moreno
  • skyflyrr
    skyflyrr over 14 years ago in reply to e14 Contributor
    James, thank you for the reply. I would like to suggest that in a future version you allow the length to be changed directly on the length box. This is such a useful feature in other cad programs.
    Thank you,
    Bob
    Bob Moreno wrote on Thu, 19 July 2012 16:03
    properties box?
    Hi Bob,
    The length field in the properties box is read-only.  But you can edit the
    (x y) coordinate of the start and end of the line so you can effect the
    length that way.
    Or, if you know exactly how much shorter you want it, set the grid to that
    exact amount and then move one end of the line by exactly one grid.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
