EAGLE User Support (English) Autorouter "Preferred Directions" selections
  • Views 1772 views
I don't use the autorouter much. The other day I was looking at the
choices for "Preferred Directions" on the "General" tab. Most of the
choices (-|/\) make sense, but what does the "*" (asterisk) mean? Is it
"any direction"?
Is there a help file or document describing the Autorouter? I'm using
6.2.0, but I couldn't find anything describing the various options.
    "any direction"?
    Correct, * is basically a don't care or use any direction.
    You can find this info in Chp 7 of the EAGLE manual which is included in
    the doc folder of EAGLE's installation directory. You can also find it
    online www.cadsoftusa.com->Training-> Manuals.
    hth,
    Jorge Garcia
    Cadsoft Support
    "any direction"?
    It means "any direction".
    If you look in the /doc subdirectory of your Eagle installation, you
    will find a manual_en.pdf file which has more information than the
    built-in Help. Specifically, Chapter 7 talks about the Autorouter in
    great detail.
    Andrew.
