EAGLE User Support (English) Pwr vs. Sup (4.16r2)
  • Views 1372 views
Can someone explain to me the difference between Pwr and Sup pin directions
when creating a part?  I've read and re-read the manual on this topic and
I'm just not getting it.  How do you decide which to use?  Thanks.
    From "help pin":
    "pwr     power input pin (Vcc, Gnd, Vss, Vdd, etc.)
    Sup      general supply pin (e.g. for ground symbol)
    If Pwr pins are used on a symbol and a corresponding Sup pin exists on
    the schematic, nets are connected automatically. The Sup pin is not used
    for components."
    This means that your Vcc/GND/etc. lines on your symbols should be "pwr"
    pins.  If not INVOKEd on the schematic, these pins will automatically
    connect to supply symbols with the same name.
    It's good practice, IMHO, to keep all connected pins visible on the
    schematic, particularly if you including decoupling capacitors.
    Andrew
    0xADF
    Am 24.07.2012 20:21, schrieb Karl Lautman:
    Help Pin
    Joern Paschedag
