EAGLE User Support (English) ULP (board name without path and extension?)
  • Views 487 views
Can anyone please write the ULP code to strip the path and the
extension from the board name (B.name)? I need to generate the very
first and the last line of the G-code as:
%filename G71*
so I need the filename without the path and the extension.
e.g. if the B.name is:
c:\some_folder\test.brd
I need just 'test' to be able to generate:
%test G71*
Chupo
    In article <juvhj1$tdb$1@cheetah.cadsoft.de>, Warren Brayshaw
    <warrenbrayshaw@paradise.net.nz> says...
    if (board) board(B) {
      string FileAndExt = filename(B.name);
        dlgMessageBox(filesetext(FileAndExt, ""));
    Thank you very much!
    Chupo
    %filename G71*
    %test G71*
    news.cadsoft.de
