EAGLE User Support (English) Whats the difference between a net and a   wire?
  • Subscribers 191 subscribers
  • Views 3893 views
When connecting pins together on a schematic, what's the difference between
using a net and a wire?
I know I'm supposed to use a net, but there doesn't really seem to be any
practical difference between the two.
  • larsen
    larsen over 14 years ago in reply to e14 Contributor
    To add a bit of confusion but also clarity:image
    In version 6.2.0 it appears that wire and net both make electrical connections. At least by looking at the rats-nest in the board view.
    Wire though, dont make termination dots and wont auto-terminate the connection.
    By the way, the tool tip when hoovering the cursor on the tools, says (in lower left)
    • WIRE: "Draw lines"
    • NET: "Draw an electrical connection"
    Which is fairly clear information - just what you need - when you have forgotten in 2 weeks.
    But the terminology is very ambigous.
    e14 Contributor over 14 years ago in reply to scott216
    On 8/5/2012 9:43 AM, scott216 wrote:
    So when are you supposed to use wire?  Is it just for connections that only go to one point?  I just finished a schematic and I have a mix, but both wires and nets look the same.  Is there a way to hide the nets so I can delete the wires?
    Wires should only be used for artistic purposes, the name LINE would be
    more inline with it's function than WIRE but for historical reasons it's
    still named WIRE.
    Never use WIRE to define connections in the schematic and in most cases
    you don't want to use WIRE to define connections on the board.
    In EAGLE there's no way to seperate WIRES from NETS.
    hth,
    Jorge Garcia
  • scott216
    scott216 over 14 years ago in reply to Nate1616
  • Nate1616
    Nate1616 over 14 years ago
    Here is a little snipit form another post that should help explain it.
    "You might think that you'd use the "wire" command to make connections in your circuit.
    However, a wire in EAGLE is just a line; to properly make actual electrical connections, you need to use the "net" command. Nets will automatically form junctions when terminated on pins or other nets; I don't think wires are so nice."
