EAGLE User Support (English) How to name a circle or arc.
  • Views 438 views
I am using a coil that has several lose pins.
Using lines and circle's, this to imitate thermals, I want them to be
connected to my ground plane.
But as I can name a line to a signal, it looks that this is not possible to
a circle or arc.
Is it possible to name a circle or arc and if so how to do it.
Regards
Harry
    Harry H. Arends wrote:
    >Tried this command but no result.
    >wire 'COIL' 16 FLAT 100
    Have you read the 'drawing arcs' paragraph of 'Editor Commands -
    Wire'?
    curve and radius parameters always need a sign, and you need a first
    point coordinate before you give a curve or radius
    try: wire 'COIL' 16 FLAT (0 0) 180 (100 0) @75 (0 0); news:d4lr28594asjoodovvkp6e2afavkekrj0i@4ax.com...
    >>a circle or arc.
    >possibly not
    >have a look at the 'curve' and 'angle' parameters of the wire command
    "Lorenz"  schreef in bericht
    >a circle or arc.
    possibly not
    Lorenz
    >a circle or arc.
    possibly not
    Lorenz
