EAGLE User Support (English) EAGLE Silent Install
  • Views 474 views
Is there any way to make a silent install of EAGLE? I work in a University, and we would like to have EAGLE installed for our students. So far I can run "eagle-win-6.2.0.exe /auto" to get it to extract automatically, or I can extract it then run "eagle.exe --setup" to make it do the normal setup, but I can't get it to do a silent install.
    Am 22.08.2012 23:33, schrieb Brandon Lee:
    In principle, EAGLE does not NEED any installation:
      1. Install it ONCE on ONE machine, so that it works there.
      2. Afterwards, for each OTHER computer, just copy all the
         files to this other computer (to any desired folder), and
         it just works.
      3. There are two drawbacks with this approach:
          a) On first start on the new machine, EAGLE needs the
             license code. But that's OK, because then the admin
             has full control over the installations, and illegal
             copies will not work.
          b) There will be no entry in the Windows start menu,
             and double-clicking on any EAGLE file will NOT start
             EAGLE. This must be done manually.
    Anyway, we do this copying procedure since about 8 years, and it works
    quite well for all operating systems.
    Andreas Weidner
