EAGLE User Support (English) UL_TEXT value resolves
  • Subscribers 189 subscribers
  • Views 482 views
dukepro
dukepro over 13 years ago
Good morning,
I have some text on the tPlace layer (21) of a board that has the value
">DRAWING_NAME".  In a ULP, the value of this element resolves to the
actual drawing name.  How can I get it's unresolved value?
    board(B) {
        B.texts(T) {
            if (T.layer == 21 && T.value == ">DRAWING_NAME") {
                dlgMessagebox("Drawing name found in layer 21.");
The above code never presents a dialog box.
Ideas?
    - Chuck
6303.att1.html.zip
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    On 09/11/2012 06:20 AM, Warren Brayshaw wrote:
    Hi Chuck
    I have no idea why the CHANGE command can recover the original text but
    UL_TEXT cannot.
    It  works differently in version 4 than it does in v5 and v6
    In v4  CHANGE  TEXT reveals the resolved text as you see it on the board.
    You dont get to see  >DRAWING_NAME  again once its been resolved for the
    initial placement on the board. It is active though because if you change
    the board file name the text changes with it, after a refresh.
    It's an easy job to code your ULP to calculate what  >DRAWING_NAME will
    resolve to so you can test for that and not  >DRAWING_NAME
    Warren,
    That's exactly what I've had to do.  Just for brevity, below are some
    code snippets.
    We usually keep the part number of each board encoded in the board's
    file name, such as "513456.brd".  We use this to place the board's file
    name in copper or silkscreen.  So with a board in hand, it's relatively
    easy to quickly identify it and the schematic/drawing from whence it
    originated.
    As soon as it gets saved as "xxx-Array", the resolved text expands to
    interfere with other board elements (component names if the text is on
    the silkscreen, or traces, pads, smd's, vias if the text is on a copper
    layer).  What passed DRC as the original file name, now has clearance
    and overlap errors.  So part of the panelization ULP converts anything
    based on the file name to just the base part number.
    It's not the perfect way to do it, but it works for now.
    Thanks for your input.
    B/R,
        - Chuck
        board(B) {
            // Extract the base part number.  This really should be
            // a project level attribute, but for the time being, just
            // pull everything in the file name up to but not including
            // the first dash.
            int dashIndex = strchr(filename(B.name), '-');
            if (dashIndex > 0)
                drawing = strsub(filename(B.name), 0, dashIndex);
            else
                drawing = filesetext(filename(B.name), "");
            // Convert the drawing names to the base drawing number
            cmd += "display none 21 22 1 16;\n";
            B.texts(T) {
                if (T.layer == 21 || T.layer == 22      // tplace or bplace
                 || T.layer ==  1 || T.layer == 16) {   // or top or bottom
    • For some reason, this does not work properly
    • T.value is the resolved string.
    • if (T.value == ">DRAWING_NAME") {
    • The workaround is below.
                    if (strsub(T.value, 0, strlen(drawing)) == drawing) {
                        sprintf(tmp, "change text '" + drawing + "' (%f %f);\n",
                            u2mil(T.x), u2mil(T.y));
                        cmd += tmp;
            cmd += "display last;\n";
            exit(cmd);
    e14 Contributor over 13 years ago in reply to dukepro
    Chuck Huber wrote:
    Here's some more specifics...  The board file is saved as 513942.
    If I just spin through all the text elements on a layer, the T.value
    has already resolved to "513942".
    board(B) {
        B.texts(T) {
            if (T.layer == 21) {
                sprintf(buf, "Text found in layer %d: %s.",
    T.layer, T.value);
                dlgMessageBox(buf);
                    dlgMessageBox("Drawing name found in layer.");
    I get several message boxes with "Text found..." (appropriately).
    What's displayed is "513942", not ">DRAWING_NAME".
    The goal is to take this board and save it as 513942-Array.brd.  In
    this case, all the drawing name texts become "513942-Array".  I want
    the ULP to spin through the texts and produce script to replace all
    the occurrences of ">DRAWING_NAME" with "513942".
    The problem is that the value of the UL_TEXT object has already
    resolved when the ULP is run.
    Using the GUI, if i do a Change->Text, the string ">DRAWING_NAME"
    shows up in the value.
    So... why is the value different in the GUI that in ULP?
        - Chuck
    Hi Chuck
    UL_TEXT cannot.
    HTH
    Warren
    news.cadsoft.de
  • dukepro
    On 08/31/2012 05:23 PM, Warren Brayshaw wrote:
    This maybe what you are after
    board(B) {
        B.texts(T) {
            if (T.layer == 21 && T.value == "\">DRAWING_NAME\"") {
    Hmmm... nope.  That didn't work either.
    If I just spin through all the text elements on a layer, the T.value has
    board(B) {
        B.texts(T) {
              T.layer, T.value);
                dlgMessageBox(buf);
    The goal is to take this board and save it as 513942-Array.brd.  In this
    case, all the drawing name texts become "513942-Array".  I want the ULP
    to spin through the texts and produce script to replace all the
    The problem is that the value of the UL_TEXT object has already resolved
    Using the GUI, if i do a Change->Text, the string ">DRAWING_NAME" shows
    up in the value.
        - Chuck
    board(B) {
        B.texts(T) {
    Warren
    news.cadsoft.de
    "Chuck Huber" <chuck.huber@dukepro.com> wrote in message
    news:k1qjrc$h3g$1@cheetah.cadsoft.de...
    Good morning,
    ">DRAWING_NAME".  In a ULP, the value of this element resolves to the actual
    board(B) {
        B.texts(T) {
    Ideas?
        - Chuck
    In version 5.12, in a board editor,
    If I specify the text value to be >DRAWING_NAME it immediately resolves to
    the board name so I can never get >DRAWING_NAME on the board.
    If I specify the text value to be ">DRAWING_NAME" I  get  it ">DRAWING_NAME"
    on the board.
    In the second case a ULP returns ">DRAWING_NAME"
    HTH
    Warren
    news.cadsoft.de
    Good morning,
    board(B) {
        B.texts(T) {
    Ideas?
        - Chuck
