EAGLE User Support (English) Help with Creating Board
  • Replies 12 replies
  • Subscribers 190 subscribers
  • Views 1169 views
I've finalized my schematic for my project but I'm having trouble
converting this to a board - a lot of the air wires (especially around the
voltage regulators, where I'm starting with laying them on my board) don't
make sense to me. As this is my first Eagle CadSoft project, I'm a bit at a
loss of how to really get going (although I've watched some tutorials on
YouTube, they seem to simple compared to my schematic).
Any tips/tricks/tutorials people can point me to? Alternatively, is there
anyone in the Toronto area who could help me? I would try to attach my
schematic but the .sch file and a .pdf are both over the 50kb limit.
    On Fri, 14 Sep 2012 09:21:41 -0400, Ross Waddell wrote:
    I'm not sure that's entirely fair, Joern. I've watched a few tutorials
    on laying out the board but they were all very simple designs. I fully
    understand that the components need to be placed on the board, but what
    surprised me is that after moving just a few the air wires connected to
    pins that didn't make sense. Rather than put all the comps on the board
    with what looked like odd connections, I thought I'd ask first.
    I'm still on Eagle 5, but I assume that the behavior is the same in 6:
    The ratsnest shows what pin is connected to what.  The ratsnest gets
    generated when a part is placed, when a board is created (by clicking the
    board icon in the schematic editor) or when you invoke the ratsnest
    command.  The ratsnest that is created makes an airwire from any given
    pin to the closest pin on the same net -- that connection doesn't change
    when you move components around, only when you do another ratsnest
    command.
    So if you start with your board freshly-generated from the schematic and
    place all your parts, the airwires will all be on the right nets, but
    they'll be going every which way.  Invoking the ratsnest command again
    will re-calculate all the shortest paths, and make things much more
    rational.
    Also, if you're laying out by hand, it's often useful to lay out a
    connection, then do a ratsnest command -- the ratsnest will recalculate
    to each bend in the wires that you've laid down, which is sometimes an
    aid to laying stuff out.
    On the tutorials:  It will be a big help if you pick out one or two of
    the simple tutorials and do them.  This will let you get a grasp of the
    basic operations before you try to do it in a great big board.  Then when
    you go to doing your board you'll be partially over getting overwhelmed
    by the tool itself, so it'll be less likely that you'll be overwhelmed by
    trying to manage the tool+board.
    On getting help locally:  Check to see if there's a local robotics club
    or (less likely) an amateur radio club that actively builds stuff.
    Someone there may use Eagle, and may either let you visit them and hang
    over their shoulder while they lay out a board, or they may be willing to
    go help you for the cost of a six-pack of something nice.
    You're welcome to come here, but Oregon is a bit far from Toronto.
    My liberal friends think I'm a conservative kook.
    My conservative friends think I'm a liberal kook.
    Why am I not happy that they have found common ground?
    Tim Wescott, Communications, Control, Circuits & Software
    http://www.wescottdesign.com
    Thanks very much, Tim. That's all very good advice and I will try with a
    simple board first.
    Oregon is a little far from here, but if I get desperate ... image
    Thanks Chuck. I think that it being called 'Layout' threw me off. I changed
    it black and it looks good now.
    I store my projects and custom libraries in Dropbox so I can work on them
    from my iMac or Macbook. The .epf is in the same project folder but I
    haven't touched my $ setting (AFAIK)
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    On 09/14/2012 07:56 PM, Ross Waddell wrote:
    That box only seems to affect the schematic view, not the board. If I click
    black it does change the schematic view, but not the board view. Strangely,
    on my laptop when I did this and then reset it to white the board changed
    to black. Don't know if it will stay that way ...
    Ross,
    From either the schematic or the board editors, try: Options->User Interface
    The pane titled "Layout" should have the Background set to Black.
    The pane titled "Schematic" should have the Background set to White.
    These settings are stored in $/.eaglerc (on unix/linux systems) as Brd.Palette and Sch.Palette.  A value of 0 is a black background, while a value of 1 is a white background.  Because of where these values are stored, they are persistent across all projects, but are specific to a user or workstation. The $/.eaglerc file is a text file that can be edited with your
    favorite plain text editor (vim, emacs, notepad, etc.)
    If these values are getting changed unexpectedly, then this file is
    somehow getting changed, perhaps by someone logged under the same user
    ID that you use, or perhaps by a tool that synchronizes your $HOME
    directory across multiple machines.  (Directory synchronization
    presented a licensing problem to a MAC user not long ago.)
    HTH,
        - Chuck
    Am 14.09.2012 15:21, schrieb Ross Waddell:
    I'm not sure that's entirely fair, Joern. I've watched a few tutorials on
    Maybe you have watched many but have not DONE things so far.
    Tudorials should be easy imho to learn the handling, the more
    complicated things come by experience.
    As for the colour setting, my Options doesn't have a special setting for
    the board layout; I only see one for the schematic layout which I want to
    leave as white (default). The default for the board view was black, so I
    don't know how it changed if I didn't do change anything.
    I don't have the english version of eagle, but at the very top of your
    .sch/.brd should be a tab "options" and if you click that something like
    "user interface" or similar should show up. Opening that tab another
    menu opens and here on the very top right you have an area to select
    your background for .sch and .brd i.e. white, black or coloured.
    Besides, eagle has a build in help or just hit the F1 key.
    Joern Paschedag
    Am 14.09.2012 01:57, schrieb Ross Waddell:
    not really related but still puzzling - while originally the background was
    black when working on the board, it's now gone white. I've moved my custom
    libraries around so not sure if that's a factor, but how do I change the
    board view back to black?
    For setting colours check the option box.
    I have looked at your drawings in general. So what do you think is wrong
    with it? You have to MOVE your parts to the position you want them
    within the eurocard frame that represents your board size (or edit that
    size and form). After moving your parts execute RATSNEST because this
    will recalculate the airwires. After you have positioned your parts you
    select the ROUTE command, click on an airwire and start making the real
    connections on the top/bottom side of your board.
    Since you imho have no idea what a layout really is you really should
    RTFM, that is not far away, because it is in your eagle doc directory image
    Joern Paschedag
    Marco - I've put the following into my Public Dropbox folder:
    Schematic
    http://dl.dropbox.com/u/70624775/eagle%20copy/Projects/TOS_E/TOS_E.sch
    Board
    http://dl.dropbox.com/u/70624775/eagle%20copy/Projects/TOS_E/TOS_E.brd
    Custom Libraries
    http://dl.dropbox.com/u/70624775/eagle%20copy/Custom%20Files/lbr_RW/Microchip%20PIC.lbr
    http://dl.dropbox.com/u/70624775/eagle%20copy/Custom%20Files/lbr_RW/Ross%20Library.lbr
    I don't know what you mean by 'assert the rats nest command', but maybe
    after reading the tutorials posted by Lupo I will.  :blush:
