EAGLE User Support (English) Trouble moving dimensions Eagle 6.2.0
  • Subscribers 187 subscribers
  • Views 216 views
  • dimension
Hello all,  after completeing a board layout in Eagle 6.2.0 Professional I often wish to use the dimension tool to show dimensions for objects such as mounting points.  I usually print screen (keyboard button) the dimensions, put it into paint, print it off, and then hand the drawing to the machine shop.  I have trouble however grabbing any dimension that is closest to the board.  For example I apply several dimensions to the left side of the board and space them out equally but looking back on it I decide to change the position of the dimension nearest the board.  I just cannot seem to grab it and move it with the move tool.  I do not have the same trouble grabbing dimensions further from the board.  It just seems to be the one closest I have trouble with and usually the closest dimension is within half an inch of the board, at least at my resolution.  Is there any trick or solution to this problem?  Thanks,
Nick
