EAGLE User Support (English) PDF2LIB or create Eagle symbols by copy/pas te
  • Replies 7 replies
  • Subscribers 190 subscribers
  • Views 736 views
Hi all,
LIBedit7 "Component Plaza" for Eagle is a CAD library Editor
that creates symbols by simply copy/paste contact names contained
in a PDF manufacturer datasheet.
The symbol is easily and quickly drawn.
http://www.libedit-informatique.com
    e14 Contributor over 13 years ago in reply to CSWalt
    Walter Spermann wrote on Wed, 21 November 2012 17:01
    <snip>
    Altium has a feature sort of like this built into the tool.  I've
    used it
    and it works great.  Other CAD tools may have similar things.
    Anything
    that reduces design effort (and time) while simultaneously reduced
    random
    hand-entry errors is welcome in my world.
    If you only have a PDF I can't imagine that it's more than copy&paste
    of
    manually chosen sections of the document into an editor window that
    parses and
    processes the input somehow. But maybe I'm really wrong here.
    That's about what the Altium solution is--but you make it sound like that's
    a bad thing.  The bottom line is, I was able to create a symbol with 128
    pins in about 2 minutes with no chance of typing errors.  Maybe I'm just
    being pragmatic but I'm happy to use copy&paste to save time and reduce
    risk of hand-entry data errors.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Hi
    James,
    {/quote]
    Quote:
    There is no guideline that a post can't be off commercial nature.
    Check
    http://www.cadsoftusa.com/forums/guidelines/ to see for yourself.
    I've
    done it some times and so have others.  If it's done with respect
    and not
    complete spam then some users will appreciate it.  I've never seen
    anyone
    from CadSoft complain when I or Falk Stricker post something with
    a
    commercial nature.
    Your tools and services are known since long time and we recommend
    them
    also to our customers (like the EAGLE Powertools).
    True.  But at one point in time you didn't know me--everyone has to start
    somewhere.
    I'm not saying this particular product is well designed or not--I have no
    idea.  Maybe you know more than I do.  And I do agree with Oliver's
    concerns about the website.  But in general, I'd say we want to encourage
    any sort of innovation around EAGLE.  Instead of just hacking it down, how
    about some suggestions on how to make the implementation more appealing to
    EAGLE users in general?
    Cheers,
    James.
    Alex wrote:
    Alex who?
    "Request a Quote" is extremly annoying for such kind of software. Is
    the pricing top-secret?
    "Contact Us" forms without indicating a mail address is extremly
    annoying.
    "About Us" telling me only "SIRET: 530 737 774 00014 Code APE: 6201Z"
    is not inspiring confidence.
    JavaScript trying to avoid mark / copy is childish and annoying.
    That's not the behaviour of people I want to make deals with.
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
  • CSWalt
    CSWalt over 13 years ago in reply to e14 Contributor
    Hi James,
    On 11/21/2012 03:28 PM, James Morrison wrote:
    Walter Spermann wrote on Tue, 20 November 2012 12:35
    >> Hi,
    >> On 09/19/12 09:52, Alex wrote:
    >>> Hi all,
    >> copy/paste from a PDF sheet ? That's a poor tinkering solution.
    >> Nothing we recommend officially.
    >> Please don't post ad-like stuff like this here !
    Actually Walter, this sort of arrangement is exactly what CadSoft has
    recommended.  When asked to create these sort of solutions into EAGLE,
    CadSoft has consistently stated that they would rather build and worry
    about a great engine and provide the ULP/Script interface and leave these
    sort of interfaces to the users to create (my paraphrase).  That is exactly
    what Alex did, so don't get bent out of shape when users do what you say
    to.
    OK, but it makes a difference if somebody wants to share his own solution
    with others for free or if it's commercial. It was not discussed with us before.
    So he put it in the wrong newsgroup. Big deal.  Really, a lot of stuff gets
    to the wrong newsgroup.  Sometimes I'm not really sure which to use myself
    in some cases.
    There is no guideline that a post can't be off commercial nature.  Check
    http://www.cadsoftusa.com/forums/guidelines/ to see for yourself.  I've
    done it some times and so have others.  If it's done with respect and not
    complete spam then some users will appreciate it.  I've never seen anyone
    from CadSoft complain when I or Falk Stricker post something with a
    commercial nature.
    Your tools and services are known since long time and we recommend them
    Has anyone at CadSoft actually tried to make a Symbol for a part that has,
    say 1000 different pins (think FPGA for an obvious example).  If you had to
    do one of those by hand (and I have with EAGLE) then you'd appreciate any
    solution to cut out any percentage of the work.
    Any solution that included cut and paste other than complete hand entry is
    a much better solution.  Hand entry leads to random errors.  Cut and paste,
    if there are errors, tend to be systemic errors which are easy to spot.
    I'll take cut and paste every day.
    The datasheet PDF is the official information that is vetted by the
    manufacturer.  So it makes sense for the ultimate solution to use the PDF
    as the data source to eliminate as many sources of error as possible.
    I'm pretty sure I've seen users request this sort of thing before.  If they
    haven't, I've certainly thought it.  So there is a need.  You may differ on
    the best way to fill the need, but at least Alex did something about it.
    Altium has a feature sort of like this built into the tool.  I've used it
    and it works great.  Other CAD tools may have similar things.  Anything
    that reduces design effort (and time) while simultaneously reduced random
    If you only have a PDF I can't imagine that it's more than copy&paste of
    manually chosen sections of the document into an editor window that parses and
    Walter
    BTW, I don't know Alex, I'm not associated with him in any way, I've never
    used the product.  But philosophically, I think we need more of this sort
    of innovation in EAGLE, not less.  The next time I need to create a very
    large symbol I'll look it up and see if it can help me.  This particular
    tool may be well designed or it may be complete garbage--I have no idea.
    But the idea behind it is solid and I hope this sort of functionality is
    incorporated into EAGLE.  Ideally right into the core of the program, but
    if not, then by users and third-parties just like Alex has done.
    Cheers,
    James.
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Hi all,
    to.
    in some cases.
    commercial nature.
    Cheers,
    James.
  • CSWalt
    Hi all,
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
  • zainka
    zainka over 13 years ago
    On 19. sep. 2012 09:52, Alex wrote:
    Hi all,
    This is a commercial and not a suggestion!
    Therefore I also guess your description above is a bit coloured.
    I suggest the post to be removed or Libedit should pay a penalty to
    Cadsoft for occupying their servers with commercials.
