EAGLE User Support (English) Excellon format
  • Views 629 views
Excellon format
I RTM but I can't find any answer to my questions. Perhaps I'm looking
for the wrong keywords.
The software of my cnc machine can read nc files with the following
limitations:
- units: mm
- format: 2:3, 2:4, 2:5, 4:2, 4:3, 4:4
Is there a way to configure the EAGLE cam processor to output a file
that meets the constraints above?
Thanks!
Marco
    Il 16/10/2012 12:39, Richard Hammerl ha scritto:
    what exactly do you want to export? Drill data? If yes, you can modifiy
    the EXCELLON device in the file eagle.def.
    It looks like this now:
    ResX and ResY define the resolution. Currently 10000 steps
    per Inch. If you set it to 25400 per inch you are in a mm grid.
    Cute!
    And for the number of decimals? Should I change something other?
    Marco
    On 04.10.2012 10:29, Marco Trapanese wrote:
    limitations:
    - units: mm
    Thanks!
    Marco
    Type     = DrillStation
    Long     = "Excellon drill station"
    Init     = "%%\nM48\nM72\n"
    Reset    = "M30\n"
    ResX     = 10000
    ResY     = 10000
    ;Rack     = ""
    DrillSize  = "%sC%0.4f\n"        ; (Tool code, tool size)
    AutoDrill  = "T%02d"             ; (Tool number)
    FirstDrill = 1
    BeginData  = "%%\n"
    Units    = Inch
    Select   = "%s\n"                ; (Drill code)
    Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
    Info     = "Drill File Info:\n"\
                "\n"\
                " Data Mode         : Absolute\n"\
                " Units             : 1/10000 Inch\n"\
                "\n"
    Hope this helps.
    Richard Hammerl
