EAGLE User Support (English) Disappearing Board Grid
  • Subscribers 189 subscribers
  • Views 1275 views
I had changed my board grid to 0.25 mil (alt: 0.0625 mil) and all was well
but when I brought up the Grid window again (so I could do a screen capture
to save it for future reference) I noticed that the grid value had changed
and when I reset it and clicked OK, the grid disappeared entirely. The only
way know to see the grid is to click 'Default'. Once I make any changes, it
disappears again (even if I just alter the default).
Is this a bug?
    Okay, so mea culpa here - I think I'm not drinking enough coffee (or too
    much - seems to have the same end effect). I was trying to set the grid to
    1 mm, *not* 1 mil (Tilmann called it). Bad eyesight, maybe? All looks
    right now.
    Doesn't matter what the grid setting is - if I set it to 1 mil it still
    doesn't show up, even with zooming in really close. Seems like only the
    default works.
    Ross Waddell schrieb:
    I did try that, of course.
    Deep enough?
    0.25 mil (6.35 µm) is a really fine grid...
    What is such a fine grid good for, by the way?
    Tilmann
    P.S. Maybe you confused "mil" (1/1000 inch) with "mm" (millimeters)?
  • fritzz
    fritzz over 13 years ago in reply to e14 Contributor
    I change the grid a lot and have not seen this.
    e14 Contributor over 13 years ago in reply to fritzz
  • fritzz
    what if you zoomed in?
