EAGLE User Support (English) PCB Libraries 2012.23 footprintscript - bugs and query
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 1579 views
  • libraries"
  • "pcb
Running EAGLE 6.2.0, Win7-64 pro. I'm using PCB Libraries' PCB Footprint Expert 2012.23 to generate import scripts for a SOP65P640X120-28L from a TSSOP-28 datasheet. There are some significant issues, listed below:
1) Running the FPX-generated import .scr scriptfile, an EAGLE error dialog is thrown:
  [path]/SOP65P640X120-28L, Line 60:
  'First' is only valid for pads
2) The outline on 51 tDocu changes width irregularly, broken into segments of 0.001mm! and 0.1mm, both of which are unusably thin for assembly drawings. Looks nothing like the preview in FPX, especially in the lack of corner chamfer near pin 1.
3) The silkscreen package outline on 21 tPlace has become a few random segments; again, little resemblance to the FPX preview. The few lines there are come perilously close to what would be the soldermask edge. Also they are way too thin (0.1mm) as-is and would have to be fattened up by the PCB fab house. There may be FPX settings that would change these, but some realistic defaults would be nice.
4) Both >NAME and >VALUE ended up on 21 tPlace, not on 25 tNames and 27 tValues as is expected and customary in the EAGLE design environment and quite common on vendor- and user-supplied parts.
The footprints as-generated and as-imported are pretty messed up, necessitating extensive cleanup to be usable -- not what I had expected from a pricey application and certainly not much of a time-saver. At least the SMT pads themselves seem okay. Those interested in reducing time spent on EAGLE footprint composition might want to hesitate before laying down $200 for Footprint Expert right away.
I'm a bit new, and it's not my or anybody else's job to debug PCB Libraries' app. But I was wondering whether anybody at Cadsoft or here might have a go at pinpointing where the script went bad. Attached is the SOP65P640X120-28N.scr file. I suppose I'll have to share any replies here with PCB Libraries as feedback (no, I don't work for them).
SOP65P640X120-28N.scr.zip
  • e14candies
    e14candies over 13 years ago in reply to e14candies
    Now they are working...someone must have been listening
  • e14candies
    None of these links arepresent;ly working (3/31/13)!
    Here's the link to Footprint Expert for Eagle -
    http://www.pcblibraries.com/Products/FPX/EAGLE.asp
    e14 Contributor over 13 years ago in reply to fritzz
    The new FPX Lite calculates highly quality accurate footprint library parts
    directly from component dimensions. The program bases the solder joint
    anaysis using IPC-7351C rules or the User can change the rules
    "on-the-fly". You can also select the "Footprint" tab and enter the
    component mfr. recommended pattern dimensions instead of using IPC
    standards.
    One part at a time means that the "Free" version allows the User to enter
    component dimesions and calculate a footprint. The User can change the
    drafting lines widths, rules and solder joint goals for each individual
    part and export the data to any one of 17 different CAD tools.
    The FPX Lite program does not have two professional features that come with
    the "Full Version".
    1. User Preference Settings allow the User to customize hundreds of Rule
    settings permanently so that you don't have to change any preferences every
    time you build a part. The Preferences include pad shapes, units,
    rotations, drafting items, solder & paste mask, solder joint goals and many
    other settings.
    2. Ability to save all your component dimensions to a FPX file. This
    feature is called the "Librarian" and it's a professional part library
    manager where you dump all your component package data. You can always
    change your Preference Rules at any time and Batch Create thousands of
    library parts with a single click. Example: You want to create a library
    with customized preferences. Select all the parts in your FPX library and
    run the component dimensions through your new preferences to create a new
    library of thousands of parts.
    The Free FPX Lite is great if you can't afford to purchase the Full Version
    or if you only build a couple parts for each PCB layout or if you're a
    casual PCB designer that only does a couple designs a year. But if you're a
    serious PCB design professional and want to manage a large PCB library then
    we recommend that you purchase the "Full Featured" verion.
  • fritzz
    fritzz over 13 years ago in reply to e14 Contributor
    I've alway been confused by what you can or can't do with the free version. What deos this new version now allow?
    What does "use it to create 1 part at a time "as needed"" mean?
    The PCB Libraries, Inc. software "PCB Footprint Expert" did originally have
    an Eagle interface bug back in September of 2012, but that was fixed in
    October 2012 and no further issues were reported since then.
    PCB Libraries now offers a free "PCB Footprint Expert Lite" (FPX Lite) that
    allows users to download and install the program and use it to create 1
    part at a time "as needed".
    FPX Lite also has 16 other CAD tool interfaces and PCB Libraries, Inc.
    provides free updates, technical support and webcast training (if
    necessary, however the program has a user friendly GUI). FPX Lite does not
    have an expiration date and users are welcome to offer product suggestions
    for new feature enhancements.
    Every Eagle user should download and install the FPX Lite program as it
    will save you lots of time and it creates highly accurate IPC-7351C
    standard footprints.
    Download here - http://www.pcblibraries.com
    Eagle users can upgrade to a full version of PCB Footprint Expert (FPX) for
    $249 USD.
    FPX will soon offer 3D-STEP models and automation for footprint creation
    for non-standard packages like 50,000 through-hole connectors with a
    mixture of plated, non-plated and slotted holes.
    Alex
    Just send this information and pictures to the software supplier as
    justification for a refund.
    Warren
    news.cadsoft.de
    Am 05.10.2012 02:50, schrieb Alex Templeton:
    PCB Libraries
    You should check that with pcb libraries image
    Eagle did nothing else than the instruction (script) said.
    Look at the script with a text editor like I did.
    Below you see the copied last 7 lines of that script and that NAME/VALUE
    go into layer 21:
    Layer 21;
    Change Size 0.7;
    Change Ratio 5;
    Text '>NAME' R0 (0 0);
    Change Size 0.7;
    Change Ratio 5;
    Text '>VALUE' R0 (0 0);
    Joern Paschedag
