EAGLE User Support (English) Ground plane Impedance, Mounting holes using Eagle
  • Views 370 views
I am new to Eagle and PCB design. Hope someone can help me with the following scans,
1. Is it possible to design a ground plane with a specific impedance using Eagle?
2. I need to make some mounting holes in eagle which will have connections to ground planes. In other words, a screw put inside the PCB can act as ground or connected to the ground plane?
3. If I have a Gerber file, is there any automated procedure to import a Gerber file into a PCB layout file in Eagle ?
Thanks in advance,
    Hello Khalid,
    I am new to Eagle
    welcome!
    and PCB design.
    You might consider to first have a deeper look at this technology and
    the related methods, before doing some real work.
    using Eagle?
    Can you explain what exactly you mean? A ground plane is a ground plane
    - it has no "specific impedance".
    Simply use VIAs for these mounting holes (connected to the particular
    signal, say GND). Select proper drill and diameter sizes. It is common
    practice to place several additional small VIAs in the restring of this
    "mounting vias" - resulting DRC complaints must be ignored or acknowledged.
    Have a look at the "EAGLE Power Tools" by Falk Stricker, they are
    available in the download section on the CadSoft website. Included is a
    useful converter from gerber files to EAGLE script files. However, take
    care that this imports just the bare copper - if you want an editable
    design, you better redraw it completely within EAGLE. (This applies to
    all CAD software, since the gerber files contain only a small part of
    the design data.)
    Tilmann
