EAGLE User Support (English) Eagle v6.3 DRC doesn't detect clearance error between two polygons of same rank
  • Views 373 views
  • bug
A simple example is attached.  Basically it notices if the two polygons overlap, but not if they just touch or the clearance is less than the default 8mils that the DRC specifies.
I'm using Eagle 6.3.
Polygon_DRC_Bug.zip
    Hi Tyler,
    This has already been reported and is being worked on. The workaround
    temporarily is to change the rank of the various polygons so that
    they're different.
    hth,
    Jorge Garcia
    Cadsoft Computer.
