EAGLE User Support (English) Suggestion for info dialog box
  • Subscribers 189 subscribers
  • Views 338 views
I'll find very useful if the information dialog box will have the
following features:
- not modal, but
- stay on top (of course within EAGLE application)
- allow to change the current object
Often I need to inspect several objects to get/set their coordinates or
any other information.
I need to close and reopen the dialog box every time I want to change
the component.
Instead I'd like I can keep open the window and just clicking on another
object.
Marco
  • dukepro
    dukepro over 13 years ago
    On 10/17/2012 10:50 AM, Marco Trapanese wrote:
    following features:
    - not modal, but
    Excellent idea.  It could be dockable like a tool bar or similar to a
    properties box in NetBeans.  Or undock it and drag it out of the
    confines of the editor window.
    Count me in on this request.
        - Chuck
    Il 17/10/2012 17:28, James Morrison ha scritto:
    I can see how that would be useful and I wouldn't be opposed to this as
    long as you can place it somewhere where it doesn't take away from my work
    space.  Altium has a info box that is actually semi-transparent so you can
    sort of see what is behind.  What would even be better would be able to
    drag it to some other corner or position in the screen.
    The best way is to make all these features customizable. So you can
    choose to have the dialog box transparent or to drag it to your
    preferred place. Who doesn't need the new behavior may just continue to
    use as usual. Open, check info and close.
    Marco
    Marco Trapanese wrote on Wed, 17 October 2012 10:44
    following features:
    - not modal, but
    the component.
    another
    object.
    Hi Marco,
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
