EAGLE User Support (English) Defining wire widt for different nets
  • Views 287 views
StefanTh
StefanTh over 13 years ago
Hi
I am trying to understand how I can make the "Auto" command draw wires width different wire widths depending on which net they belong to.
Preparation:
1) First I press the icon "Drc", switch to the Tab "Sizes" and choose "Minimum Width" to 10mil
2) Then I enter the "CLASS" command to get up the "Net classes" window
3) I leave the line "default" as it is (Width 0mil) and add a new line with the NAME "RAWPWD" and setting the width to "30mil" and press the button "OK"
If I now press the icon "Auto" or enter the command "AUTO" all the lines are drawn with the 10mil width, even those net's that is named "RAWPWD".
I thought that the AUTO command should consider the settings in "Net classes" window but it seems only to consider the "Drc" setting.
I do not know if it is because I have the Freeware version or not.
Regards
  • StefanTh
    Right click on a wire and in the pop up window change the "net class" to one of the defiend classes
