EAGLE User Support (English) Project folder alias : $PROJECTDIR
  • Subscribers 189 subscribers
  • Views 482 views
so, it can be feasible to store Gerbers in different directory
e.g. $PROJECTDIR\Gerbers\%N.cmp
I think it is very easy to implement !
    e14 Contributor over 13 years ago in reply to CSWalt
    Walter Spermann wrote:
    >$PROJECTDIR is not unique. You can have many of them.
    >You'd need something like $PROJECTDIR[n] for n-th project dir.
    Is the path to the current eagle.epf unique?
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
  • CSWalt
    CSWalt over 13 years ago
    There are already a number of aliasses for CAM output (%D, %E %P etc.).
    If you exchange the order in the directory setup this can be quite confusing.
    Supplying the $EAGLEDIR as alias could be an alternative.
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    Over the years, I suggested many times to add an $EPFDIR placeholder
    (and $BRDDIR $SCHDIR). No sucess so far...
    Sure. Who know why CadSoft doesn't want to implement it.
    BTW: My way to start Eagle is assigning eagle.exe to *.epf files. My
    setting for the "projects" folder in Eagle is just ".". There is no
    all-embracing Eagle projects root on my storage. Eagle projects are
    just subdirectories next to other project data (software,
    calculations, mechanical stuff...).
    Oliver
    Oliver Betz, Munich
