EAGLE User Support (English) Unit toolbar buttons "INCH" "MIL" "MM"
  • Views 1729 views
to easily change the board current units.
or (far better) to include these unit change buttons in dialog boxes for the user to switch easily between imperial and metric system.
    This can be accomplished by adding your own user menu in your SCR
    directory. Make sure that Command Texts is turned on in the User
    Interface options and then run the menu SCR you just added.
    MENU
         'MM : Grid mm;'\
         'INCH : Grid in;'\
         'MIL : Grid mil;'\
