EAGLE User Support (English) Texas Instruments CAD Libraries for Cadsoft EAGLE can't be loaded
  • Replies 7 replies
  • Views 1152 views
I want to apply the TI CAD library for eagle and I have followed exactly the instruction:
1. Download and extract the file.
2. Copy the library file (.lbr) to EAGLE library folder; "C:\Program Files\EAGLE-X.XX.X\lbr" (X.XX.X is your EAGLE software version)
3. Start EAGLE software.
4. Under EAGLE Control Panel, go to the Library tree and browse for new copied library (.lbr) file.
5. Right click on the library and select "USE".
However, this file can't be loaded because the software gives the warning that the lbr. file contains invalid files.
I'm using Eagle 5.11.0 professional version.
Could someone please help me?
Thanks!
    Hi, I found a way to select a single part, which is a satisfying tempory solution.
    1. Add the particular part to a new, separate library.
    2. Save it.
    3. Export in v6 as script
    4. Import in v5 and correct the script.
    If someone has a general solution for all parts, it would be great!
    I tried. After 10 minutes I have edited 1% of the entire bibliothek. How could I skipt the warning for each part/ each mistake in the script so it can correct it automaticly. Or maybe I can only correct the script for a single device? I tried also to cut the device, but the cut function is not available in the light version.
    Thanks!
    Yue Zhang <noreply-144025@element14.com> wrote:
    thank you very much for you replies.
    C://Programme/EAGLE-5.11.0/scr/Texas Instruments element14.scr, Zeile 82: Unbekannte Change-Option:Align
    Edit the scr script...
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    I tried this method:
    Are the TI libraries eventual for V6?
    If yes, and you don't have a V6 license, this might work:
    - Download and install V6 in addition to V5 without deleting V5
    - Load the TO library in V6
    - Export as script
    - Open V5 and import the script
    But when I wanted to import the script, following warning is given:
    That's why the library couldn't be loaded properly.
    Give an link where to download the TI libraries.
    http://www.element14.com/community/solutions/6448/l/texas-instruments-cad-libraries-for-cadsoft-eagle-software
    Thanks in advance!
    Schöne Grüße
    - Export as script
    Bye
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    On 11/07/2012 05:04 AM, Joern Paschedag wrote:
    Am 07.11.2012 10:31, schrieb Yue Zhang:
    >> TI CAD
    Most likely it is a Version-6 library which cannot be used in a
    Version-5 program directly.
    Where did you get this library from? I could not find it at Cadsoft
    download site.
    Some of the TI product pages offer Eagle libraries. I know they offer
    MSP430 libraries.
    Eric
    TI CAD
    download site.
    Joern Paschedag
