EAGLE User Support (English) manufacture eagle gerber issue.
  • Views 224 views
hello
I have just tried to manufacture my gerber file.
it was created in eagle , 4 designs merged on one panel  266mm x 161mm
it is tested in gc-prevue. and imports fine no errors.
heres a pic:
the board house say max 500mm x 500mm and any more than two designs will
induce a fee.
so i am within the limits but will be charged extra for the 4 designs.
so i send my .rar containing the gerber files.
They email me back and say:
"We have reviewed your Gerber file. Unfortunately, we cannot make the panel
as Gerber shows.
It's too big to apply stamp holes between it and V-cut cannot apply on it
as it's not triangle shape.
So We suggest you order these boards separately through our online order
form. 5% discount can be used if you order them together. "
I do not understand what they mean. Have i done something wrong?
if i order them seperately it will cost 3 times as much. i simply cannot
afford that.
The way they have typed that email message , makes me feel I have no hope
because I am a novice and they know that.
This board house has the best deal on price I can find. so i was really
hopiong to use their services.
please , can anyone help ?
thanks qwerks. : )
    On Thu, 08 Nov 2012 13:58:48 -0500, john wrote:
    hello
    heres a pic:
    induce a fee.
    panel as Gerber shows.
    it as it's not triangle shape.
    I do not understand what they mean. Have i done something wrong? if i
    afford that.
    hope because I am a novice and they know that.
    thanks qwerks. : )
    Your attachment didn't come through.  I'm not sure if this newsgroup
    allows them.
    Do you want them to make stamp holes or v-cut lines?  Or are you happy
    with getting a panel and sawing out your individual boards by hand?
    You probably sent Gerbers with a dimension layer, and that layer probably
    had the board outlines shown individually.  If you're willing to whack
    things out yourself, change that to a dimension layer with one large
    outline that catches all the boards.
    OTOH, if the manufacturer will respond perhaps you should ask them what
    you need to do to get what you want -- and remember that spending time
    helping beginners to understand their process costs money; if they are
    unwilling then keep looking for a board house that will until you find
    it, at which point you can consider that you're spending some bux on
    boards, and some bux on learning how to use the cheaper places later.
    My liberal friends think I'm a conservative kook.
    My conservative friends think I'm a liberal kook.
    Why am I not happy that they have found common ground?
    Tim Wescott, Communications, Control, Circuits & Software
    http://www.wescottdesign.com
