EAGLE User Support (English) Customise net labels with XREF on
  • Views 251 views
zainka
zainka over 13 years ago
Hi
Normally I have used only the textbased net labels on line that goes
from one sheet to another. My wish is to use the XREF option but I am
not comfortable with the format options
My "big" problem is that the signal name for a given net label comes
inside the flag. I would prefer all symbols to be of equal size and to
have the text align on beside of the net flag instead.
not like this               but like this
   ______________________          _____
-/NET_LABEL_SIGNAL_NAME |       /     | NETLABEL_SIGNAL_NAME
  \______________________|        \_____|
If not existing as an option already I would recommend to make the order
of the label xref formatting tags relevant (as set in misc menu) to the
result. Se my examples below:
                  ________________
%F%N (%S)      / NETLABEL (1)  |
                 \________________|
                  _____
%N %F(%S)      / (1) | NETLABEL
                 \_____|
                  _____
%N (%S)%F      /     | NETLABEL (1)
                 \_____|
Here everything coming in front of the %F tag ends up outside the flag
and everything after %F ends up inside. The flag symbol would thus have
a minimum size like say 3 letters.
Second. Is it possible to have flags indicating direction of a net? I.e.
if signal is in, out or bidirectional. This should be possible to change
with a change command like for example CHANGE DIRECTION or CHANGE FLAG
if not existing as an option already somewhere.
input             bi              output
   _______          ______         ______
_/       |       /      \       |      \
  \_______|        \______/       |______/
I will add these my suggestions to the suggest forum if this is not
possible to achieve pr. today.
Breg
Vidar (Z)
    good idea! I agree with that!
    Alberto Vignati
    Il 17/11/2012 23:42, Vidar (Z) ha scritto:
    Hi
                      ________________
                     \________________|
                      _____
                     \_____|
                      _____
                     \_____|
    input             bi              output
    _/       |       /      \       |      \
    Breg
    Vidar (Z)
