EAGLE User Support (English) "Permission denied" error with import-bmp.ulp
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 4816 views
Import-bmp.ulp was working with no problem.
Suddenly I started to get an error "Can't open C:\Program Files (x86)\EAGLE-6.2.0\lbr\bmp.scr". "Permission denied."
Maybe it has something to do with Windows 7 security settings? But I didn't change anything there.
Any help appreciated.
/tipo
  • tyllurius
    tyllurius over 5 years ago in reply to Pedro147
    October 2021 - same here for "import-dxf.cfg permission denied". I don't understand they don't fix problems that appear again and again, over years... Thanks Andrew!
  • Pedro147
    Pedro147 over 7 years ago in reply to zukuwyatt
    June 2019 - same problem again and I forgot Andrew's solution image Thanks again, it still works brilliantly
  • Pedro147
    Pedro147 over 9 years ago in reply to zukuwyatt
    Thanks Andrew Wyatt - perfect solution image
  • zukuwyatt
    zukuwyatt over 9 years ago
    I have an easier solution: Run Eagle as administrator
    I realise this is an old thread, but it's #1 in Google when searching for "import-dxf.cfg permission denied", so others will likely find themselves here.
    autodeskguest over 12 years ago in reply to e14 Contributor
    It sounds like you are another one (like me) that has encountered the
    Windows "virtual store" - that is where windows puts things that you think
    you are writing to it's "protected directories" so it puts it down in the
    "virtual store" under your account instead and does not tell you about it.
    Strange things can happen.  The virtual store is in
    "C:\Users\mikey\AppData\Local\VirtualStore" (obviously change the account
    name to yours).  Take a look in there and see if that was where it was
    putting it.  You can encounter the same thing with user libraries you
    create - you think you are saving them in the same spot as where Eagle
    install put the libraries, but in reality, it is down in the "virtual
    store".  Can be quite confusing since it is not obvious that windows has
    done it.
    mikey
    I had the same problem under Windows 7 x64.
    Here is a quick work around.
    Open Notepad and "Save As" the blank document.  Set "File name:" to "bmp.scr" "Save as type:"  to "All File (*.*)" and save the file to your desktop.
    On your desktop, right click "bmp.scr" and select "Take Ownership".  Now move "bmp.scr" to the Eagle "lbr" directory
    Run the "Import-bmp.ulp" file and all is good.
    Mark Perry wrote:
    /tipo
    Import-bmp.ulp builds the bmp.scr file in the folder the editor has open.
    You are using a library this time. Was that how you used it previously?
    Perhaps you used it directly in a project and that folder is not a branch of
    Program Files.
    There is Win7 security to prevent you doing that
    If it was, maybe something turned off redirection. The Win7 security can
    redirect files, where you appear to write to Progam Files but in fact it is
    in another folder.
    If you are doing it the same way a before, then your Win7 changed for some
    reason, maybe and update or if on a Domain the admin has changed policies
    etc.
    HTH
    Warren
    news.cadsoft.de
    Forgot to add that there is no 'bmp.scr' in 'C:\Program Files (x86)\EAGLE-6.2.0\lbr\ folder'.
