EAGLE User Support (English) Problems Printing in 6.3
  • Views 312 views
dukepro
dukepro over 13 years ago
I ran into a problem printing schematic pages in 6.3.0 on linux.  A job
is submitted to the CUPS, but nothing ever prints.  Reverting back to
6.2 avoids the problem.
Has anyone seen a similar problem?  If so, how did you fix it?
    - Chuck
        - Chuck
    I run 6.3.0 on Gentoo, and printing via CUPS from Eagle works fine for me.
    Typically, though, I just print to PDF and do my printing from a PDF viewer.
    You might want to try that to help isolate the issue.
    Whenever I have CUPS issues I always look at the following:
    1) the CUPS web interface at http://localhost:631. Occasionally the error
    message shown besides the printer there is useful. Often it isn't.
    2) more often, I end up examining the CUPS error log in /var/log/cups.
    Changing the LogLevel variable in /etc/cups/cupsd.conf to 'debug' (then
    restarting CUPS) will spew tons of information in the logs and usually show
    what is tripping up the output.
    The paths I show above may not be the same paths used on your distribution.
