EAGLE User Support (English) Eagle Schematic: How to force net orientation ?
  • Views 408 views
alertjean
alertjean over 13 years ago
Is there any way in Eagle schematic editor to force the orientation of net ?
For example I want nets connected to parts always bend at right angles when you move a part  (i.e always use manhattan distance routing)?
By default nets bend in arbitrary direction when a part is moved creating clumsy looking schematics.(Or manual movement of wire is needed for right angle bends)
    Hi Jean,
    I hope you're doing well. There's nothing in EAGLE right now to force
    this, if you stick to a 0.1"(2.54mm) grid on the schematic and pay
    attention to good schematic composition this mostly becomes a non-issue.
    hth,
    Jorge Garcia
