EAGLE User Support (English) Clearance detection for polygon doesn't work
  • Views 471 views
I am working with eagle 6.3 and I am facing 2 problems. 2 polygons with same rank ( if they don't have the same rank there is no problem) are getting too close to each others, beyond the isolation limit. but the DRC doesn't seems to detect this clearance problem. It will be detecting this only when the polygons limits are overlapping see on the screenshot below the 2 cases :
No DRC error, whereas the clearance is obviously not respected.
When overlapping the 2 polygons it detects the problem.
Is there an option to activate to detect these kind of error in DRC ?
Another problem I found is that ">LAST_DATE_TIME" is not computed at CAM processing. Even if I saved before. Should i do something specific to have it correctly processed ?
Thanks for your help.
    Ok I've just seen that 6.4 fixes that problem...
