EAGLE User Support (English) Using OS_SIGNATURE in Script File
  • Views 264 views
Is there anyway to use this new feature of OS_SIGNATURE in a script file?
I go back and forth between Windows and Mac a lot and my eagle.scr file
using the command key in assign commands.  However, on Windows this creates
a warning when that file is read in, one for every time I use it.  And I
use it a lot.
It would be nice if I could have a script line for each OS and EALGE would
know only to ignore other lines, something like
if OS_SIGNATURE == "Windows"
  some_command_for_windows
else if OS_SIGNATURE == "Mac"
  some_command_for_mac
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    James Morrison wrote:
    file? I go back and forth between Windows and Mac a lot and my
    eagle.scr file using the command key in assign commands.  However, on
    Windows this creates a warning when that file is read in, one for
    every time I use it.  And I use it a lot.
    would know only to ignore other lines, something like
    I feel the solution is likely to be; have eagle.scr RUN a ULP that tests for
    the OS and that results in running either a script containing MAC assigns or
    one containing Windows assigns
    HTH
    Warren
    news.cadsoft.de
