Neil Allison schrieb am Sun, 22 March 2009 16:40
>> How do I see a list of which nets belong to each class?>
RUN statistic-brd.ulp and check CLASS tab there. You can
doubleclick
the net class there and you will see the list of nets that belong
to this class.
If you are interested in a visual approach, I wrote an example ULP
"show-netclass-by-layer.ulp" that defines the layers 190 Class0, 191
Class1, ... 197 Class7. It then draws (or traces) wires on the layer
corresponding to the class of every net. You might be able to modify
it
for your particular requirements.
It is available in the ULP download area of the Cadsoft website.
Cheers
Neil
Thanks for nice and usefull ULP, but i would have one question. How i could
bring the "colors" back? UNDO - Command is not the best idea :(. Is there
any ULP as solution?
Thanks for your answer
Tom
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
