EAGLE User Support (English) Auto-Router and Polygon Cost Factor
  • Subscribers 187 subscribers
  • Views 226 views
Hello all,
I don't use the auto-router all that often, but when I do I always find
that the polygon cost factor is not enough.  If I have poured a polygon for
a power rail then I don't want a trace to ever go through it.  So I want an
auto-router configuration flag to say never run a trace into a polygon.
Currently, the cost factor will try to avoid the polygon but it will still
put the trace there if it must.  In many cases, this simply is not
acceptable and I'd rather it fail out than run through the polygon.
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
