EAGLE User Support (English) Why @1, @2 appear after "Package" name?
  • Views 183 views
On same board I have packages "0805_CHIP", "0805_CHIP@1", "0805_CHIP@2".
Basically it is the same package.
What did I do to make this happen?
How can I get rid of those @1's and @2's?
Or should I just not care?
Tipo
    Does anybody know?
    The only comment I find in manual doesn't help me to understand.
    "Library objects with the same names
    The Text Editor shows this message if you attempt to load an older file
    (BRD
    or SCH) that contains different versions of a library element. In this case
    it
    added @1, @2, @3... to the names of the Devices so that they can be
    identified."
    /tipo
