EAGLE User Support (English) Duplicate PCB tracks and connect them to other components.
  • Subscribers 190 subscribers
  • Views 462 views
bmoe
bmoe over 13 years ago
Hi.
I have four operational amplifier chips with the surrounding components in exactly the same position relative to the OP chip.
I have routed all the tracks/wires to the surrounding components on one OP and i wonder if it is possible in any way to copy these tracks, and paste it to the other OP blocks and make it connect to those components.
In this way I get four identical blocks without having to route all the tracks over and over.
/M
  • dukepro
    dukepro over 13 years ago
    On 01/16/2013 08:15 AM, Matias Sjögren wrote:
    Hi.
    As of 6.0, Eagle supports sub-circuits.  I believe you would want to put
    your op-amp and surrounding accoutrements in a schematic/board by
    itself, then include that schematic/board in your design.  You'll have
    to read the manual for the details since I have not yet had occasion to
    use it.
    HTH
        - Chuck
  • jamodio
    jamodio over 13 years ago
    You can certainly use copy and paste to copy pieces of a layout but the issue with signals is that each one is a separate signal so you will have to change the names one by one or as needed. You can turn off the layers you don't want to copy.
    My .02
    -J
  • bmoe
    No one knows?
