EAGLE User Support (English) Unable to open one 4.16 BRD file in 6.4.0
  • Subscribers 187 subscribers
  • Views 327 views
CalebCZ
CalebCZ over 13 years ago
Hi all, I have encountered a weird problem - one 4.16 BRD file doesn't convert into 6.4.0 properly. The editor displays only board outline (layer Dimension) and some auxiliary lines in layer Measures, almost everything else is missing. I have imported dozens other 4.16 and 5.12 projects so far, but this is the only file which failed to convert. I have also tried to convert it to 5.12 first (that was apparently OK) and then move to 6.4.0, but the result was the same. I tried Googling it, but it appears to be fairly rare problem. I'm attaching the BRD file to this post. And here is XML converter report:
EAGLE update report
Date: 25.2.2013 15:20:22
File: C:/Program Files/EAGLE-6.4.0/projects/hub/hub_mega64.brd
The file has been loaded into the editor, but there have been
warnings while parsing the intermediate XML file.
The XML file has been loaded into a text editor window as
C:/Program Files/EAGLE-6.4.0/projects/hub/hub_mega64.rpt.brd
Warning(s):
line 791: skipped unexpected tag <param>
line 792: skipped unexpected tag <param>
line 793: skipped unexpected tag <param>
line 794: skipped unexpected tag <param>
line 795: skipped unexpected tag <param>
line 796: skipped unexpected tag <param>
line 797: skipped unexpected tag <param>
line 798: skipped unexpected tag <param>
line 799: skipped unexpected tag <param>
line 800: skipped unexpected tag <param>
line 801: skipped unexpected tag <param>
line 803: skipped unexpected tag <autorouter>
line 894: skipped unexpected tag <elements>
line 1613: skipped unexpected tag <signals>
hub_mega64.zip
    EAGLE update report
    Warning(s):
    http://www.element14.com/community/message/70733#70733/l/unable-to-open-one-416-brd-file-in-640
    hub_mega64.zip
    Hi Caleb,
    It appears there's some extraneous baggage in the XML file. This is easy
    to fix with a good text editor like Notepad++. If you don't feel
    comfortable fixing it send it to support@cadsoftusa.com and they will
    take care of it.
    Best Regards,
    Jorge Garcia
    EAGLE update report
    Warning(s):
    hub_mega64.zip
    Hi Caleb,
    take care of it.
    Best Regards,
    Jorge Garcia
