EAGLE User Support (English) quotes skipped in directory names / 6.4
  • Subscribers 189 subscribers
  • Views 306 views
  • google_drive
  • path
  • bug
flegmatoid
flegmatoid over 13 years ago
Eagle 6.4 LE Windows (Win7, 64-bit) seems to have a bug with parsing double-quotes in directory names.
I.e. Google Drive application creates a following folder: C:\Users\admin\„Google“ drive\
Then, in Eagle: Options->Directories->Projects->Browse - above folder is added
The newly added folder is parsed succesfully, projects are loaded. However, after closing Eagle and starting it again, a message popups: "The directory C:\Users\admin\Google drive\ doesn't exist - create it?". Notice, the double-quotes have dissapeared in the directory name.
The same record, withouth double-quotes is also present under Options->Directories->Projects.
The next time eagle is started, the projects folder is now "C:\Users\admin\?Google? drive" (instead of absed double-quotes the questionmark appear)
  • flegmatoid
    flegmatoid over 13 years ago in reply to e14 Contributor
    apologies for the late reply
    Unfortunately, google drive doesn't alow to customize its folder name, only the path that folder resides within. Its a know google drive issue.
    Even if it would, the recomendation of yours would rather be a hack, than a fix to the problem. It is obvious Cadsoft Eagle cannot parse non-standar double-quotes and replaces them with the questionmarks before saving the path so registry or some *.ini file.
    By the way, which is the palce the "directories" are saved? Maybe tuning the particular file entry manualy would resolve this problem?
    On 2/27/2013 4:38 AM, Flegmatoid Zoid wrote:
    http://www.element14.com/community/message/70871#70871/l/quotes-skipped-in-directory-names-64
    Hi Flegmatoid,
    Does the Google Drive have to have the double quotes in it's name. Could
    you rename it in such a way as to avoid the double-quotes. In this
    context such a path string would give problems.
    My recommendation would be if possible to rename the drive so that it no
    longer has double quotes.
    Additionally did you browse to this folder in OPtions -> Directories or
    did you type in the path. If you use the Browse button you allow windows
    to add the string correctly.
    hth,
    Jorge Garcia
