EAGLE User Support (English) how to change value of a group?
  • Views 1072 views
Can somebody please tell me the correct syntax  for using the ULP
"cmd-change-value-group.ulp"?
If I try to run the ULP from within the File menu I get an error box stating
"No VALUE specified", and then, there is no way for me to specify any value.
I suspect that the answer is to use the command line, but I can't figure out
syntax that is acceptable.
Too bad the Change command does not work for Value, because then
theoretically you could just right click a group and then Eagle would ask
"New Value for Group?", or something like that.
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:kgk82f$qim$1@cheetah.cadsoft.de...
    Brett Holden wrote on Wed, 27 February 2013 13:42
    stating
    value.
    figure out
    ask
    You need to run this ULP from the command line.
    The ULP description shows this.
    RUN cmd-change-value-group.ulp VALUE
    So if you grouped some Resistors and Capacitors and wanted to make all
    resistors in the group 10K then you would type
    RUN cmd-change-value-group.ulp 10K R
    To make the capacitors 0.1uF you type
    RUN cmd-change-value-group.ulp 0.1uF C
    Don't try it just yet because its likely a vesion 5 ULP that has been
    included with 6.4 and will not work. Some changes occurred to
    part/instances in v6.0.0
    Use the attached one which I modified to work.
    @Alf You may care to review and swap in this one.
    HTH
    Warren
    Web access to CadSoft support forums at www.eaglecentral.ca.  Where the
    CadSoft EAGLE community meets.
    Hah. Your new ULP works great, thank you.
    stating
    value.
    figure out
    ask
    HTH
    Warren
