EAGLE User Support (English) PS vs. PDF
  • Replies 12 replies
  • Subscribers 189 subscribers
  • Views 1818 views
PS vs. PDF
dukepro
dukepro over 13 years ago
Jorge,
One thing I don't understand is the strategic decision to print via PDF
format as opposed to print via PostScript.  I understand that the
languages were defined by the same company, but PS is a far more
portable format (supported on linux, mac, windows, BSD, and just about
any unix derivative you can name).  Additionally, many printers support
PS natively.  In the rare cases where you needed a PDF (as in print to a
PDF file), ghostscript, or ps2pdf are good candidates.  In contrast, I
don't know of any printers that support PDF format natively, so you'll
always have a backed process that converts PDF to the printer language.
By emitting a PDF format, you leave it to the print subsystem to convert
it to PS, and then to the printer's native language.  This happens every
time one prints as opposed to the rare times when one prints to a PDF.
I guess my point is that every time the data goes through a format
conversion, there is a risk of conversion errors causing problems.  So
the fewer conversions, the less likely of a conversion problem, and the
more efficient the overall process.  After all, isn't that what
engineering is all about - avoiding potential problems and efficiency?
I welcome your thoughts on why PDF was chosen rather than PS.
    - Chuck
    Tilmann Reh <usenet2007nospam@autometer.de> wrote:
    >selsinork schrieb:
    Guest wrote: I have never seen that process produce erroneous
    results. Printing from a PDF file is a solved problem and a
    reliable process.
    Try exact scale 1:1 from a PDF. It's not too good. Mainly due to
    printer tolerances and lack of control in PDF to fix it. I'd agree
    that PDF for general text documents (or schematics) is perfectly
    fine.
    >Just for the record: PDF, just like PS, basically is a vector oriented
    >data format containing numerical information (unless we are talking
    >about embedded pixel graphics).
    >So it has exactly the same precision as PS. If there are any tolerances
    >in printing, they are caused be the printer or the driver, but
    >definitely not by the file format.
    Agreed. It's usually the driver, trying to second-guess that causes
    the most trouble.
    /"\ Bernd Felsche - Somewhere in Western Australia
    \ /  ASCII ribbon campaign | For every complex problem there is an
    X   against HTML mail     | answer that is clear, simple, and wrong.
    / \  and postings          |  --HL Mencken
    selsinork <selsinork@gmail.com> wrote:
    Guest wrote:
    I have never seen that process produce erroneous results.
    Printing from a PDF file is a solved problem and a reliable process.
    >fine.
    Printing PCB artwork to a laser printer for one-offs is quite
    difficult with all those arbitrary scaling processes in the chain.
    You notice the problem especially if you use an NC machine to drill
    the holes for you even on a moderately-sized PCB (half-Eurocard).
    One has to resort to fiddling with scaling factors and re-checking
    long (orthogonal) dimensions on the printed output with e.g. vernier
    calipers.
    You're absolutely correct, it has very little to do with the format itself.
    Much more to do with native PDF printers being comparitively new, multiple conversions between formats behind the scenes in the driver and not all the pieces having caught up. For example, when I print artwork direct to PS (not with eagle I hasten to add) I can individually control x & y scaling to compensate for printer discrepancies, but that either isn't an option or simply doesn't work properly for PDF.   Yes, I'm quite sure cups and it's strange multiple conversions isn't helping at all here.
    I'm equally sure that at some point, when native PDF printers are as common as PS ones are today, these problems will get sorted. But until then...
    reliable process.
    fine.
    Tilmann
    e14 Contributor over 13 years ago in reply to dukepro
    Chuck Huber wrote:
    Case in point: Eagle has trouble printing hashed lines due to its
    backend PDF software.  I'm having this problem on linux, and others are
    having this problem on Macs.  The problem I was having first surfaced in
    6.3 and carried into 6.4.  It was /not/ present in 6.2.  It shows up
    when printing to a PDF file, then manually sending the PDF to the host's
    printing system.  It is /avoided/ when printing to a PS file, then
    manually sending the file to the host's printing system.  So it is
    specific to the way Eagle produces a print job.
    Or it's something to do with how cups is mangling the file? Have a read at the link Bob posted and then start to wonder why it has filters like 'pdftopdf' - yes, that's converting a pdf to a pdf...
    I'd be interested in how your PDF prints when it's sent directly to a natively PDF capable printer without going through the hosts printing system as I suspect cups may be the culprit here rather than generically the PDF format.
    Try exact scale 1:1 from a PDF. It's not too good. Mainly due to printer tolerances and lack of control in PDF to fix it. I'd agree that PDF for general text documents (or schematics) is perfectly fine.
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    On 03/01/2013 01:45 AM, Bob Johnson wrote:
        - Chuck
    I suspect it has little to do with Eagle and a lot to do with Qt and the
    general move to PDF as a print job format. This page discusses some of the
    reasons:
    http://www.linuxfoundation.org/collaborate/workgroups/openprinting/pdfasstandardprintjobformat
    Interesting reads.  I was not aware that PDF provided significantly more
    functionality than PS.
    Thanks for the research.
        - Chuck
    Chuck Huber wrote:
    In contrast, I
    Unfortunately anything using recent CUPS as the printing system (i.e. any recent Mac / Linux) is doing PDF as the backend printing format. So app produces, PS, cups converts to PDF to mess with it, cups then converts back to PS to send to the printer. Yes I agree this is nuts. (having recently been round this loop where the cups PDF to PS thing produces PS files that don't print when the original PS does)
    However, most recent (non bargain bucket) printers can handle PDF natively. My new laser does PCL5, PCL6, PS 3, PDF 1.5 natively
    Chuck Huber wrote:
    Jorge,
        - Chuck
    reasons:
    And here:
    http://lwn.net/Articles/485617/
    For general printing, the page-oriented font-embedding nature of PDF makes a
    lot of sense. For 1:1 printing, I don't know, but then again, 1:1 printing
    has always been a can of worms.
  • dukepro
    Olin,
    I agree with all three of your points.  PDF the best way to go for
    documentation purposes.  I'm not suggesting doing away with printing to
    a PDF file.  The name even implies that it's tailored for "documents".
    Instead, I was referring to the internals of Eagle regarding how print
    jobs are produced.  Currently, that process is to produce a PDF then
    send it to the host.  On unix systems (I include linux and OSX in this
    reference), the PDF is first converted to Post Script by the host
    printing system, and then to the printer language (but only if the
    printer does not support PS natively).  This conversion is sometimes
    problematic.  The idea is that if Eagle produces a PS print job and the
    printer understands PS, then no format conversion is needed.
    I was asking Jorge of the motivation to produce PDF for print jobs
    rather than PS.  What was it the engineers saw in PDF that caused the
    team to select that format for print jobs?  Assuming they were aware of
    the prolific support of PS on unix systems, what was it about PS that
    drove the decision to produce PDF's for print jobs?  I want to
    understand /why/ PDF was chosen over PS in light of the conversion
    overhead and conversion risks incurred in doing so.
    Enjoy,
        - Chuck
    On 02/28/2013 09:03 AM, Chuck Huber wrote:
    Jorge,
        - Chuck
    0488.att1.html.zip
