EAGLE User Support (English) Text Box Width of Name Dialog in Symbol   Editor
  • Subscribers 187 subscribers
  • Views 267 views
Could CadSoft please change the width of the name dialog in the Symbol
Editor (and other places) to be wide enough to display the actual text.  I
have long pin names on many devices and it's a real pain to verify the name
is correct as you can't see the entire string by default.
To be clear, this is the dialog that comes up when you select the name
command then select a pin in the symbol editor.  This could be generalized
to all uses of that command.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
