EAGLE User Support (English) How to use the CAM option
  • Views 711 views
  I wanted to send a PCB to a board manufacturing vendor. Pls. tell me how to generate the gerber files to be sent for fabrication.
Arvind Gupta.
    Il 01/02/2013 07:03, Arvind Gupta ha scritto:
    OK thanks. Also is ther any way to read the gerber file generated in Eagle (to verify if all layers have been correctly chosen).
    Just search for 'gerber viewer' in google.
    I use GC-Prevue, but you may choose your favourite one.
    Marco
    Arvind Gupta.
    Il 31/01/2013 12:58, Arvind Gupta ha scritto:
       Sorry for not clarifying the issue. When I select Gerber274x.cam option, only top, via and pads get selected in the layer menu where as I have several labelling in tPlace etc. so do I ahve to manually select the used layers as well or am I doing something wrong. (Eagle 6.3)
    You have to select the layers you want to include in each gerber file.
    Just check if the default ones are good for you.
    Marco
    Hi Marco,
    Arvind.
    Il 29/01/2013 12:09, Arvind Gupta ha scritto:
    Have you already read the EAGLE/CAM Help, the tutorial pdf file
    available in the doc folder and searched for step-by-step tutorial on
    the web?
    Exactly, where do you face the difficulties?
    Marco
