EAGLE User Support (English) Ratsnest for a single net
  • Views 884 views
If you want to ratsnest a single net the only option is currently to type
the command followed by the netname in parentheses.
If you need to incrementally make adjustments to a polygon's shape, there is
no way to simply "repeat" the last operation. All that typing can get
tedious. And slow.
So, give us an additional drop-down menu option such as: "Tools > Ratsnest
(.) " where Eagle waits for the user to mouse-click on a single net to
operate on. Or, give us a syntax for typing the "ratsnest" command, to be
followed by a mouse-click on a single net to operate on.
    >tedious. And slow.
    for the time being, try the following ULP assigned to a function key
    cut here <<<<
    string cmd;
    if (!board) {
      dlgMessageBox("to be used from board editor");
    else {
      board(BRD) {
        BRD.signals(SIG) {
          SIG.polygons(POL) {
            if (ingroup(POL)) {
              cmd += " " + SIG.name;
              break; // ratsnest works on signals -> no need to check the
                     // remaining polygons of the signal
      if (cmd)
        exit("ratsnest" + cmd + ";");
      else
        dlgMessageBox("no polygons found in selection\n\nctrl-click to
    select, then re-run ULP");
        exit("group");
    cut here <<<<
    Lorenz
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:kevi7j$mj1$1@cheetah.cadsoft.de...
    type the command followed by the netname in parentheses.
    No parenthesis needed
    e;g; ratsnest GND
    there is no way to simply "repeat" the last operation. All that
    typing can get tedious. And slow.
    Up Arrow repeats the last typed command or the earlier ones, that's quick.
    Ratsnest (.) " where Eagle waits for the user to mouse-click on a
    single net to operate on. Or, give us a syntax for typing the
    "ratsnest" command, to be followed by a mouse-click on a single net
    to operate on.
    HTH
    Warren
    news.cadsoft.de
    Whup.. what I meant was having to type the command, and netname  -in single
    quotes- (not parentheses). But you're right, it works without single quotes.
    And thank you for setting me straight on that.
    But I still think it would be a worthwhile improvement to be able to
    ratsnest a polygon by entering some command (or clicking a drop-down menu),
    and then clicking on the polygon's edge, instead of having to type the
    command and the net name.  I am not that big on using only the keyboard.
    e;g; ratsnest GND
    to operate on.
    HTH
    Warren
    news.cadsoft.de
