EAGLE User Support (English) Resistor packages
  • Subscribers 187 subscribers
  • Views 824 views
Resistor packages
I am trying to place RN55 (RNF14) & RN60 (RNF12) style through-hole
resistors.  What is the proper package to use? I suspect it is 0309/12, but
wasn't sure if there is a more direct way to look it up. These are very
common parts.
    autodeskguest over 13 years ago in reply to autodeskguest
    The RN60 is 3.68mm by 10.8mm so you'd need the next size up.
    Since these are common parts, I was expecting to simply search for RN55,
    RN60 styles & have  the correct parts already established under THOSE
    names, especially if I did not have the dimensions.  I suppose that is a
    bit perilous approach.
    as far as
    The through-hole resistor packages are labelled by dimension, such that
    xxyy/zz means xxmm wide by yymm long body with zzmm pad spacing.
    are the libraries explained somewhere?  By that I mean an explanation of
    how the libraries are set up:
    if you need a RESISTOR they are organized using..... (width, length,
    spacing)
    if you need a FUSE they are organized using.......
    if you need a CONNECTOR they are organized using...
    common parts.
    As somebody answered in another thread just the other day...
    The Vishay datasheet gives the RN55 as 2.3mm by 7.06mm so an 0309/12
    provides reasonable space around it.
