EAGLE User Support (English) Command Text Vertical Spacing
  • Views 324 views
In V6 the vertical spacing of the command texts seems to have been
increased, at least on the Mac OS version.  Could you reduce the vertical
spacing a bit so that it matches what V5 had?  I use those a lot and with
the current spacing of V6.4 the texts don't fit vertically onto my screen
where they used to fit just fine.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
  • CSWalt
    CSWalt over 13 years ago in reply to autodeskguest
    On 03/15/13 11:45, Eric Stevens wrote:
    On 03/14/2013 07:51 PM, Warren Brayshaw wrote:
    James Morrison wrote on Fri, 15 March 2013 09:25
    vertical
    with
    screen
    Cheers,
    James.
    I on the other hand (Windows) want it larger than before. The previous
    reduction in size,  driven by James, if I remember correctly, made the
    Text
    Menu button harder to target, reducing productivity. This may be
    caused by
    the screen pixel density of the user as other postings have requested
    that
    icon size be scalable due to reducing size as screen resolutions have
    increased with higher pixel densities.
    Warren.
    I use Eagle on Linux, Mac and Windows. I find my productivity reduced
    with the current larger spacing on command texts on all systems. As with
    James, my texts no longer fit on any of my screens and I find that
    searching over a larger area for what I need is visually strenuous over
    longer periods of time. I use those commands a lot.
    Obviously, UX design is subjective, but it would be really helpful to me
    to have a setting to switch back to the smaller spacing.
    we hab an extra patch in our Gui libraries in version 5 to make it more dense.
    However, we removed it because the texts are a little cut off and therefore look ugly
    (e.g. if you have several 'g').
    Walter Spermann
    Walter Spermann
    Softwareentwicklung
    CadSoft Computer GmbH
    Pleidolfweg 15
    84568 Pleiskirchen
    Tel.: 08635/6989-10
    www.cadsoft.de
    autodeskguest over 13 years ago in reply to autodeskguest
    Cheers,
    James.
    reduction in size,  driven by James, if I remember correctly, made the Text
    Menu button harder to target, reducing productivity. This may be caused by
    the screen pixel density of the user as other postings have requested that
    Warren.
    Cheers,
    James.
    Warren.
