EAGLE User Support (English) Change Mitering of All Traces?
  • Subscribers 187 subscribers
  • Views 581 views
Apparently my board house cannot handle the rounded mitering of my traces.
Is there a way to change the miter style of all of the traces on my board?
it would certainly be a lot of work to redraw them!
Scott
    autodeskguest over 13 years ago in reply to autodeskguest
    Hmm... Maybe the slight curvature of the 45 degree bends is just the way
    they are rendered?
    Thanks for your response. It seems like the curving I am talking about is
    not stored in this way, though. The word "curve" can't be found anywhere in
    the file except on some tPlace/bPlace stuff. They are not curved lines -
    They are 45 degree lines with a slight curve at their joint. I can manually
    get rid of this mitering in Eagle. How else could this info be stored?
    Scott wrote:
    traces. Is there a way to change the miter style of all of the traces
    on my board? it would certainly be a lot of work to redraw them!
    Scott
    I don't believe there is a way in Eagle to do that in one fell swoop.
    Some would say, "Change your board house" .
    Assuming version 6 with it's XML data file you can manipulate the XML text
    directly.
    Here's a technique that will take the "Curve" from the wires and make them
    straight lines.
    Use a text editor that can search using a regular expression. Notepad++ is
    an example.
    Make a copy of your board file to practice with
    Open the board file (copy)  and search for the layer 1 wires with curve and
    replace it with text that does not have curve imformation.
    FIND WHAT     "layer="1" curve="[\-\.0-9]+"
    REPLACE WITH   "layer="1"
    Save the file
    Open the board in Eagle and check that the straightening of the curves has
    not caused a short
    Repeat the process with changes for the bottom later 16 if needed.
    HTH
    Warren
    news.cadsoft.de
