EAGLE User Support (English) directory troubles
  • Subscribers 189 subscribers
  • Views 556 views
directory troubles
e14candies
e14candies over 13 years ago
I have a schematic/board project project with both files stored in s:/halo
However, when I open Eagle control panel my project folder icon shows
empty.
The control panel shows
Projects
  >Eagle
     >SolarProj (with its files)
     >RF28Vboard
      Halo
note the Halo folder icon is not preceeded by an "arrow" & the icon is an
open folder style regardless of whether I click on it.  However clicking on
it brings up/removes the green dot.
If I click to the left of Halo the folder icon does change and I get either
a right arrow or blank (probably since the folder appears empty).
How do I "add" these files so eagle knows they exist.  At one point they
were showing up in the folder, not sure how they disappeared.
    autodeskguest over 13 years ago in reply to e14candies
    On 3/21/2013 11:46 AM, Hoyt wrote:
    another thought...why would ever have to TYPE a path...this seems quite
    error prone...shouldn't the file browser be able to take me anywhere with a
    few clicks (no typing) & pick up the name of any files or directories?
    Hi Hoyt,
    Click on the field you wish to add the path to, and then click the
    browse button on the bottom left. This will allow you to define the path
    without typing anything.
    Best Regards,
    Jorge Garcia
  • e14candies
    e14candies over 13 years ago in reply to e14candies
  • e14candies
    also, perhaps I am confused.
    I want to put each of my future projects in different locations  with their
    own directories, pdf files, software listings, photgraphs, etc
    S:\motorproject
         \pictures
         \testdata
         \pcbfiles  (eagle files go here)
    S: \radioproject
          \soundfiles
          \datasheets
          \excelfiles
    T: \airplanenav
           \flightdata
           \purchase orders
    etc
  • e14candies
    DO YOU MEAN THIS?
    $HOME\eagle;$EAGLEDIR\projects\examples;$EAGLEDIR\PROJECTS\s:\gnweed\haloge
    n\pcb
    it doesn't work and says:
    J:\program files (x86)\eagle-6.4.0\project\S:\gnweed\halogen\pcb
    doesn't exist...do you want to  create it, etc, etc...maybe I should say
    yes.
    note that eagle is on the J drive, my project is on the S drive
  • bmoe
    bmoe over 13 years ago
    Try to add your project folder in Eagle directories if its not already there, to make it show up in eagle.
    In Eagle Control Panel window, chose Options/Directories...
    In projects you can add your project folder and so that itl looks like this: $EAGLEDIR\projects;s:\halo
