I spent already a lot of time to write this ULP. But the Eagle and command
promt is the terrible combination! Im testing it but I still find there a
bug. For example: If you have a spacebar in the name of new directory (Test
v1 - command promt will create two directories "Test" and "v1") Yes I shold
use "_" but is 20 years or more old rule. Next much bigger problem is, if
you have a space bar in the file name (Test_board v1.brd). Then DOS accept
just 8 charachters (Test_b~1.brd) but whats happend if you have there 10
different versions v1,v2,....v10? If its running on background the user
hasnt it under controll. I would really reccommned to add CAM Command to
editors commands in new versions of eagle.
Tom
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
